Lawn Cher'
- Westampton, NJ
Folks, just found out we are relocating back to NJ in May. As such, I have even more stuff to sell, too many projects and nowhere enough time to work on them, and I don't want to drag all the stuff back east that I brought out here 8 and a half years ago.
The list:
Anything you could want from a '97 XJ Sport, 4.0 engine has less than 100k miles on it and ran recently on whatever fuel was still in the tank from whenever it was last filled, probably 9 years ago. AX-15 transmission, grey interior. Being parted out.
'89 MJ Eliminator project, really wants a resto-mod, originally a manual tranny 2wd. Has a bed liner & cap, bucket seats, full gauges. I have an extra 4.0 with an AW4, 242, D30 & D35 w/ 3.55's to swap in. Rocker panels need replacing. Would like to sell as-is.
'87 MJ offroad project. This is the ugly beast I've been wheeling, needs quite a bit of bodywork but the bed I started building is pretty cool if I do say so myself. Drivetrain runs fine, D30 (ARB) & D44 (spool) have 3.55 gears. I have a ford T-18 w/ Dana 300 & adapter and a Jeep bellhousing that I was going to swap into it for a granny gear. Sits at 6" on 33's and has stout bumpers w/ a Milemarker 10,500 hydro winch. Would prefer to sell as-is but may part out.
A set of 4 military Hummer wheels & tires with the internal beadlocks.
A D30 high pinion w/ 4.56 gears, Powertrax No-Slip locker, Warn hub conversion and inner shafts, solid round stock & heim joint crossover steering, includes drop pitman arm. Has virtually zero miles since build.
A D60 high pinion from a F350.
A D44 high pinion housing from a F150.
Suspension for 8", includes Skyjacker coils, leaves, Rusty's Hydro shocks, Clayton's Long Arms. Installed and never wheeled, so its all in good shape.
A D44 low pinion housing from an early Bronco w/ parts to convert to disc brakes. Also has radius arms and poly bushings and a new set of ball joints.
A D44 rear end from a Scout that matches the EB D44 nicely.
Two sets of steel wheels for the 5 on 5.5 axles mentioned above, one is 15x8, the other 15x7.
A Dana 20 transfer case from an early Bronco.
A Milemarker 9000 hydro winch.
A receiver mount winch cradle.
Winch bumper, unknown manufacturer.
Crankshaft & connecting rods pulled from a 258.
MJ gas tank in excellent shape.
MJ gas tank skid.
'97+ XJ gas tank skid.
XJ/MJ front skid.
MJ tailgate, red, in great shape.
MJ 2" receiver hitch, mounts to stock bumper brackets.
Miscellaneous stock Jeep wheels & tires.
All sorts of miscellaneous parts from other parted XJ/MJ.
Please PM me for prices, I don't get on here as much as I should.
The list:
MJ gas tank skid.
XJ/MJ front skid.
