Majo
- Watertown, NY
I have all the following items for sale. They are all located in Watertown, NY but can be moved to Potsdam, NY if it provides a more convient place for you to drive to pick them up.
Transmissions
$70-NP435 recently rebuilt with new bearings. Divorced 2wd version.
$75 takes a complete 4wd NP435 and a 2wheel drive NP435 for parts or if you want to swap it over to a 2wd case.
$100 - Ford NP205 adapted to the NP435 listed above. If you want the 205 and the 435 I'll sell the combo at 125 firm.
$100 - AX15 out of an 89 YJ. Shifted fine and recently pulled for an auto swap. Bellhousing has the spot machine for a CPS. Internal slave, and 23 spline output.
Motor
$100 - 4.2L out of an 89 YJ, this 4.2L is the widedeck version and thusly a 4.0 HO head can be bolted onto it. Ran very strong (turned some 35's with 3.31 gearing). It has an oil pan skid on the oil pan too. Think STROKER project. No reasonable offers refused. I will include a 4.0 HO head and renix and HO intake and exhaust manifolds and any other 6cyclinder stuff I have.
Axle
Dana 44 out of an 88 Jeep Cherokee. 3.55 gearing, brakes completely rebuilt 1 year ago(new wheel cyclinders etc..) It is currently under my rig right now. If you want to come up and swap it out over a weekend and put it under yours I'd be willing to let it go for $150 firm. I will include the shorter driveshaft and a YJ yoke for the output of the NP231. This means you'll give me your rear axle (dana 35 or chryco 8.25) with the same gear ratio 3.55
Aftermarket Clutch fan for 4.2L, will work with 4.0's. make an offer.
Transmissions
Motor
Axle
