I think I have the 4.5" angle grinders down with the cutoff wheels, flap discs, and grinding wheels. These typically run at 12,000 RPM at have a bunch of power, typically around 1HP. But what about the polishers and finishers which typically run at 4500, 6200, or 9000 RPM with about the same power. What are they really used for? I suppose they'd be used for sanding discs.... But why would you use a 5" sanding disc when you can use a DA sander?
They have large "eraser wheels" by 3M and others that you can use to get rid of pin striping and double sided trim adhesive tape off. The ones at Wal Mart (made by 3M) are often meant to be used in a drill at no more than 3,450 RPM. Would you try to buy a slow speed inline die grinder for something like this as a drill alternative?
And what about wire wheels? I see they go from 1" to past 4". The 4" ones are often rated at 15,000 RPM. Do you really want to run them at max speed? Or are they better used at a slower speed such as on a 9000 RPM sander/polisher tool?
