Properly setting or calibrating it (what ever you want to call it) raised the rpm shift points of mine noticably. All I can figure is the prior owner had worked on the transmission and I guess he forgot to set or do the cable adjustment.
The manual says with the engine off, to push the cable release button, retract the cable self adjusting mechanism all the way (push the cable plunger inward), then release the button, then open the throttle body to wide open, then press the button again, then release the button then release the throttle and you are done. The mechanism self adjusts using this procedure.
