GroversXJ
- Peoples Republik of Kalifornia
modify your mechanical fan shroud?
Has anybody ever modified their mechanical fan shroud to help it suck more air thru the radiator by having it wrap around the fan a little further?
What I mean is on the top of the fan, the shroud covers most of the fan blades for protection of anyone sticking their head under the hood when the engine is running I would assume, but once the shroud goes below the height of the rad that big shroud is cut way back and only extends about an inch from the main shroud body, so I was thinking about adding a little plastic or sheet metal to the sides and lower part of the shroud to allow more suction from the fan thru the rad. What do you think?:anon:
