Modified center console
420manche
Here's some pics of how I modified th xj center console I had installed in my Comanche.
Notched the main body, fabbed up some little brackets,
the metal bracket on bottom holds the modified heat tube cause I liked how much faster the cab warms up with it, no need for this side to be pretty
Reason for the notched heat tube
That was a factory cup holder that slid into 2 slots where it mounted but once you put a drink in there it would fall. Well it doesn't fall off any more & most drinks fit snugly
