Fuel90 said:
me and a friend are looking to go to moab in the next couple of weeks. neither of us have a lot of seat time, but still want to do some challenging trails, and of course some that may be a bit more scenic. i've got 4.5" of lift on 31's open front and rear. my friend is in a ranger with 6" of lift, 35s, and locked front and rear. any reccomendations?
thanks
Yeah, how about "Don't get in over yer head"? :laugh3:
Be sure to research the trails in the area before you try them, there's lots of resources available that describe the trails and equipment/lift/tire requirements to safely handle the trails.
Most importantly, go prepared. Tow points front and rear, tow strap, spare parts (U-joints, front axle shafts, steering linkage, ignition parts, sensors, water, oil, belt, spare tire) good flashlight, blankets, etc...
Having open diffs presents a bit of a challenge in itself - especially where Moab is concerned. Take your time, plan your line. The terrain out there doesn't require alot of tire speed to climb obstacles so stay off the stoopid pedal. Air down to around 12-15 psi.
Your buddy with the locked Ranger should have very little trouble out there and will likely be helping strap you over obstacles.
If you've never been to Moab before, It's always a good start to drive thru Arches National Park. You'll see lots of sights there.
A fun, gorgeous trail that I feel is a must do is "Steel Bender". Green valleys, stream crossings, rock obstacles, sandstone climbs and canyon overlooks. With a neat finish of a large creek crossing and steep climb up to see some "petroglyphs" on the canyon wall at the end of the trail.
