MJ springs on an XJ with Shackle relocation brackets???
Supermanxj
Is this a plausible setup??? Did search and I came up with three or four threads about length...Something like five inches longer, 2" in front 3" in rear or vise versa.
But what i am not sure about is if the relocation brackets will be enough and where the axle will sit on the center pin???
Any input is appreciated!
Josh
well if its 2 inches longer in the front your axle will still sit 2 inches back reguardless of the relocation bracket, i dont really see a great advantage to doing the swap, whats the motivation behind it?
You will have to move the front mount to get the center pin in the middle of the wheel well.
Im using Dodge B van half ton springs. Same lenght from front bushing to the center pin as the XJ, but about 2" longer in the rear.
