Tito_73*
- California
Ok I'm back after a 5 day break. I guess this is some info for bcmaxx since you have the same issue. I cleaned my t-body, removed my idle stepper motor cleaned the pintle and cleaned the orifice that the pintle seats in. I got a much better idle now, but sadly I still have the hot-start miss. I purchased the non contact thermometer. I was checking my underhood temp with a hot engine my block seemed normal around 210. I started checking the fuel rail, then each injector. All were the same except for #2, don't remember the temp, but I could touch #1 with my finger and I was ok. But when I touched #2 ouch, hot. Then I started it up, misfire, disconnected #2's connecter, no change in rpm found suspect cylinder. I connected a spare injector and felt it clicking, circuit is ok. It finally dawned on me bad injector right, wrong. I had been here once before. I then realized one of these things is not like the other. #2 did not have the retaining clip holding the injector to the fuel rail. So when the rail was pressurized it bottomed out the injector causing the body to contact the intake, resulting in the injector getting to hot when I shut off the engine. I need to confirm this by going to the local junk yard and getting a clip. I will let you know if this fixes it, maybe then I will be worth the :worship: emoticon
