misc xj, zj, and mj parts
Vanimal
escondido, ca
i gotta clear some stuff out of my yard to make room for new junk.
here's the list:
HP dana 30 non disconnect housing, and only the housing, no knuckles, or anything else, except ball joints. double shear shock mounts welded on, and i believe the sway bar mounts are modified, and not very pretty. $50
reinforced hp d30 dif cover. it has a thick ring (maybe 1/4"? around the perimeter where the bolt holes are, and a 2" wide or so strip that goes from the top to the bottom to protect the front. $10
brand new in box dakota rear body to axle brake line. it's around 22" vs the xj's stock 14" line. direct replacement, good for lifted xj's. $20
tomken zj lift springs, supposively 6". should work on a zj, may net a little more lift? $100
mj gas tank $25
front sway bar with relocation brackets $25
red 94 zj doors, good shape. $50 each
red zj hood, good shape, $35
ppi dcx 800.5 800 watt 5 channel amp. it's a pretty large amp, probably over 2 feet long. $125
sony xplod bandpass box with 2 10's in it, works and looks good. $60
various 94 zj parts, make offer:
power seat rails
grey air bag
grey various dash pieces
steering wheel and steering column
gage cluster, 360k
abs brake parts
ecu
radiator
air conditioning condenser and various parts
radiator support
hugs and kisses
trans crossmember and trans mount (different from xj)
might be interested in the MJ gas tank. short bed or long bed? does is come with the fuel pump assembly?
no clue, no pump though. came with a parts zj i got, which wasnt a mj, just happened to have the tank and a bunch of random stuff with it.
Dibs on the Sony subs
no skids
2 people in line for the subs, wazzuxj, lemme know on the housing. $10 plus the shocks?
is the diff cover custom made?
i think so, but i could be wrong. looks decent, i'd run it if i didnt have a heavy duty cast iron one.
i can try to get pics. btw, did you ever find zj springs for a 6" lift? those tomken ones are listed on their site as 6". i think the coil wire diameter is a bit thicker, making them settle less, but have a lower overall height when unloaded.
and subs are gone!
