Misc XJ parts etc
jeeptec
2000 XJ crossmember. Great shape. Has 2 holes drilled for transfer case skid plate mounting. Includes 2 mounts that in very good condition. 1 straight mount. 1 offset mount. $25.00
2 gas tank/ hitch frame mounting plates new with new studs and nuts. $15.00
2 stock upper control arms. Good shape free
Gas tank heat shield free
Transfer case shifter bracket.$5.00
249 tail shaft seal.$5.00
2 new JK Dana 44 bearings $25.00
4 coil spring spacer 2 are stock 2 are 3/4 inch $10.00 for all
ARM air filter. Aproxx 9 inch long 3 1/2 if mounting hole. $10.00
I believe auto correct is conspiring against your AEM filter.
PM sent on the gas tank/hitch/frame nut strips.
Just to clarify is that AEM a dry filter?
