- Bakersfield, CA
Over Labor Day weekend I was at the Delta jet sking......had a blast. I forgot how much I enjoyed that place, used to keep a boat there. We stayed at Tower Park Marina off of Hwy 12 between I5 and Rio Vista.
Unfortunately, I blew a head gasket (and possibly worse) towing the two big 3 person skis up there. It took me 7 hours on Friday to get 45 miles from Bakersfield and back. The aux fan wasn't working, diagnosed that a diode in the harness that keeps current from the temp switch going back to the A/C compressor was bad. Since Jeep only sells a new harness (NOT!!), a new diode was soldered in, which didn't last very long. I took it back to the shop and he found a heavier diode, but didn't like it because the diode still got real warm, even though the wires on each side were fine. A toggle switch was installed direct to the fan relay to assure that the fan would work and I wouldn't get hot towing the skis in the afternoon. I had just replaced the radiator and fan clutch, so had confidence that if the aux fan worked there was no way that it would get hot.
Well, the fan quit working, even with the toggle switch, and so did the temp gauge/idiot light. By the time I figured that something was going on and pulled over, it was hot as blazes and the motor died before I got stopped. I got the fan working with a hot wire, and fixed the blown heater hose, but it got hot again before I got to the next off ramp, with bubbles into the coolant reservoir. Damn!!!!!
So, now I have to decide whether to tear it down and fix it or just swap in my spare motor. The spare runs perfectly, but has 210k on it, and the truck only has 117k and the motor was rebuilt before I got it.......because it got hot!
Well, at least I had a great weekend, other than Friday.
