funk_1964
- mattoon, il
whoa better check your shit
Equipment List
- Visibly charged fire extinguisher (BC or ABC)
- First aid kit
- Adequate spare tire, jack and lug wrench
- Safety belts for driver and any current passenger
- Adequate attachment points in the front and rear of the vehicle:
- Acceptable forms of attachment points: (All Items must be mounted in a manner to provide adequate strength and integrity)
- Tow hooks of OEM or greater integrity
- D-Rings
- Shackle/Clevis
- 20ft 10,000lb snatch strap without any metal hooks
- Secured battery (no bungee cords)
:twak: lets be serious for one min
tow hook that is bolted to a welded on bumper is stronger than a welded on hook? WTF
you fawkers are wheelin xjs for crying out loud.... not much to bolt to
the worst part is he had to back off an obstical under his own power b/c noone would hook up a fawkin strap
well I'm not trying to start anything here, but if you knew that you're rear bumper was not fit to pull off of why didn't you speak up?.
Would you want a tow hook coming through your window? Lets get this back on track. You live and you learn. If you guys want to join great, if not so be it. This is a great group of guys that would help anyone within reason. Welds can break easier than the bolts used will shear. Both ways are good to mount things when used in the right application.
The WELDED TOW HOOK RULE is nver written anywhere. Thats why I was like WTF when I was hanging off a ledege aand they wouldnt pull me upStop whining, rules are rules buddy. Get your jeep up to spec and then you can come out with us.
the tech guy said his shit was good!sorry, please replace REAR with FRONT. still does not change the meaning of my post. What a tech inspector says goes, the same can be said for trail leaders. If they don't feel your rig is adequate enough to wheel with the group than you are done, which is obviously what happened. Hopefully you understand that. That is all.
It passed techWhat a tech inspector says goes, the same can be said for trail leaders. If they don't feel your rig is adequate enough to wheel with the group than you are done, .
by his shit i ment facts and potential members have the right to know the truthWhy because his Jeep is built right? Other than that D30!But seriously, You don't have to be like that we are trying to help dozer out and you jump in here being all nasty. I may have sounded like a prick in the initial post and I apologize if i did. If you have problems with
, don't wheel with us. Doesn't hurt my feelings. Now seriously, Lets get this back on track and forget about this. We are trying to attract members not run them off.
plus when they checked mine they said cool !!!! HA
It passed tech
