old_man
- Loveland, Colorado
I have been running a 4.7L stroker for around 110k miles and its performance has slowly dropped. I found that my map adjuster crapped out. I originally set it up on a dyno, but I don't want to spend that much money at this point is not a good option.
I have been thinking it might be cheaper to put a wide band O2 sensor in the exhaust. I am an electronics engineer so I would do my own reader using an Arduino. What is a reasonably cost (aka CHEAP) sensor out there? I also would need a O2 sensor bung to weld into my header. Anybody have a cheap source?
Before everybody jumps on me on what I should do first, I am measuring the compression and am planning on measuring the cam lift to make sure the cam hasn't rounded off.
