I have an exhaust leak where the manifold meets the downpipes. I have a 00, so I have two manifolds and two downpipes. On one of them, both bolts are slightly bent, the threads are F'd up, and so I can't tighten or get the nuts off. Any suggestions on how I can cut them off, drill them out, etc since its tight quarters up there? I'm trying to avoid having to remove the manifolds to get in there since that's a serious PITA. If I can get/cut the nut off, then I can pull them out and drop in some grade 8s.
