qwerty247 said:ok so in hg it would be 11.8, how does that sound?
qwerty247 said:had a good look today and cant see any breaks or split vacuum pipes and all look ok.
also checked the brake booster and works ok as well as the pipe going from that.
so that leaves the map sensor or could it be a crack in the exhaust manifold casuing the low vacuum reading?
i can hear a slight hissing but with all the other noise not sure if that maybe normal
