OverlandZJ
NAXJA Member # 101
- Bristol,PA
This is a factory refurb unit that is in good physical condition except that it doesn't power up from the internal battery compartment. It does work on 12V external power though, so would be fine for in-vehicle use with a full-time 12V power source. I didn't try to fix the battery compartment issue, so maybe it can be opened up and fixed. Comes in original box with manuals and discs, as well as 12V power cable, Serial data cable, Swivel vehicle mount, Lanyard, and Mapsend Topo V3.0 software.
I recently bought this to use with Topo on a PC. Found i can use my Nuvi with Topo/SD card so i dont need a second GPS. $50
The power issue is common on this and there is a fix on the net. But would work fine if left plugged into the cig lighter.
