Flip kit would be easy enough just gotta make sure your driveline doesn't smash into the transfer case in case it's too long. Your LCA's will be at an opposite angle thou so iirc for cars when they are at a negative angle they won't perform well. Ideal is flat control arms.
Do like everyone else... Don't lower it just fill it full of rim![]()
Side note, my buddies 22" wheel with low profile tires off his chevy truck weighed noticeable more than my 31" mud terrain on a 15" soft 8... Total waste :-/
you could mount some mustang 18" wheels on it with forged alum(lighter is better for unsprung weight) I think they are 5x4.5 you might need spacers to clear the caliper though.
I'm lowered about 2" all around. Addcos front and rear. Ironman4x4fab control arms and custom straight track bar(poly on all), Springworks(CA) springs(-2", tho I specified -2.5"), Daystar rear poly bushings, MORE bombproof MMs. I'll get the height of the top of the front fender and the top of the rear roof from ground tomorrow, but am on 255/60-15 tires that are 27" tall(mushy on stock 15x7" classics). Out of 70 drivers, I got 34th place with the Jeep at last weekend's auto-x. . I beat '06 M3, '10 Z4, '02 M3, '08 335i, '03 Mini S, 'o9 328i, '87 325i, '97 2.0l z3, modded '05 M3, same modded '05 M3 with diff driver, modded '98 M3, modded '06 Mini S, modded '05 Mini S, modded '08 Mini S, modded '09 Mini, modded '11 135i, modded '07 Mini S, modded 328ci, modded '97 Z3, modded '02 325i, modded '91 318is, modded 323i, modded '99 M3, modded '05 M3, '92 Miata, '01 Z28, '03 Corvette, '07 Impreza, '06 Corvette, '10 Genesis, '02 Corvette Z06, '04 R32 GTI, '12 Camaro SS, '11 Genesis, '04 RX-8, '93 240SX, '01 Type-R, '03 S2000, '03 S2000, '13 Corolla, '13 FR-S, '93 Miata, '02 S2000, '96 Miata, '84 Peugeot, '08 S2000, '08 335i, '09 328i, '13 FR-S, '10 Genesis, '03 S2000, '98 M3, and I'm probably repeating cause many of these folk ran am and pm(I ran my M3 am and Jeep pm). My Jeep kicks @$$ and does compete with BMWs and Miatas.
Go to page 1 and click on Darky's link. There's a pic of it in the 2nd half of the 24 pages. I had to get one to center the axle back under the vehicle(raising it pulls it driver's side, lowering it pulls it passenger's side).
here it is: http://www.naxja.org/forum/showthread.php?t=8655&page=22
Yup:Has anyone done this?
2WD. From centerline of wheels: 38" from ground to hood in the front and 61" from ground to roof in the rear. Yesterday I picked up some 3.73s w/ 30K from a Liberty for $20, so now will find another 8.25" to mod to SUA. The 4.10s are just too much gear for 27" tires and when I used the 24.8" Yokohama&Silverstar setup, every gear shifted one up and 1st was pointless. I won't be able to use the flat packs I have on there now, and do want stiffer springs, so I might look into the Deaver$ or a custom composite setup. The front really can't go lower without sectioning the front tube like was done by someone else here(I'd like to be 1-1.5" lower F). The rear I want 2.5-3" lower and that can't happen unless SUA.
