49erRider
- Fort Mill, SC
Ok almost have my front axle out, but those lower control arm bolts are TIGHT! Any advice as how to get them out by yourself, don't have any help for a while.
Thanks
Thanks
Thanks
If they still will not budge use a piece of pipe and square tube as a helper to get some leverage.
grind the nut off...
Personally, I prefer to keep hardware in it's original state, so that it can be used again. And I'm pretty sure he does too.
Breaker bar is the key. I know i've dropped the ball on getting down there to help you. If I get a free weekend in the next couple of weeks i'll be down there for sure!
Ive got air tools and a compressor, if you cant get this off, I can bring down to you to finish the job.
Ever find access to a transmission jack so we can swap them out easily?
