no genuine iac now
Well my vacuum at the manifold is fluctuating pretty good. I don't have any reason to think the gauge is broken but I borrowed it from a friend who had never used it.
https://youtu.be/gnb12BEDUfI
Low and erratic, web search seems to diagnose valve springs. I will try to get ahold of another gauge to do a dummy check.
Fuel pressure is a perfect 49
another view of a plug with what looks like oil on the threads. it does read as oil on paper towel. I don't seem to be visibly burning any or missing much oil from the crankcase, not sure if this is from a previous leaking valve cover or what.
The bouncing needle is perfectly normal. Some gauges have a small valve to dampen the oscillations of the needle. The amount of vacuum at idle doesn't seem that low to me.
https://www.youtube.com/watch?v=vh3Z-F6KGkI
I watched this video and the wobbling needle on the gauge later still looks a lot better than mine.
In the video, he's using a gauge meant for checking engine vacuum that has some dampening. The dampening is typically added by a restricted line, a weighted needle, or oil in the gauge. You're using the gauge on a mity vac hand pump which has no dampening so you're going to see the pulsing more pronounced at idle as each cylinder pulls on the intake stroke. If the needle is consistently dropping a lot once per rev rather than bouncing around at 6x the revs, then I'd suspect maybe a problem with one cylinder and then do a compression test which would be much more revealing. Even slowed down to 1/4-speed, I don't see more the needle wagging more than a few psi.
The gauge set I use to sync motorcycle carbs measures each cylinder separately and you can really see the oscillations on each piston stroke. This gauge set has valves on the vacuum line you choke down to get a reading steady enough to balance the carbs.
