- MilkyWay Galaxy
I have a seperate detailed diagnostic thread at:
http://www.naxja.org/forum/showthread.php?t=934960&highlight=Taurus
that started as an OBD-II misfire code on V-6 Taurus (my sons). I fixed several problems, bad wires, worn plugs, all the details, extensive details and data, including a busted hose and coolant leak while on the freeway doing 60 mph, and subsequent overheating which are in the old thread.
It has 81 PSI compression on the misfiring cylinder #1,
Ok I need some final opinions please!
Firing sequence is 1-4-2-5-3-6 then back to 1
Compression listed in firing order is:
81 PSI (Cyl 1)
125/120 PSI (Cyl 4)
145/155 PSI (Cyl 2)
150 PSI (Cyl 5)
155 PSI (Cyl 3)
115 PSI (Cyl 6)
Compression difference in firing order is:
+41 psi ( 1 to 4)
+20 psi (4 to 2)
+/-5 psi (2 to 5)
+5 psi (5 to 3)
-40 psi (3 to 6)
-34 psi (6 to 1)
What is curious here is that only Cyl #1 is showing up as misfire now, and cyl 1 to cyl 4 has the largest + pressure difference value, +41 psi difference in cylinder compression. The Haynes says 100 PSI minimum and says no more than 15 psi difference between the highest and lowest cylinders. The highest is Cyl #3 and lowest is Cyl #1, 155 - 81 = 74 psi difference.
Wet and dry compression for 4, 5 & 6 were the same. Compression tests were on a COLD engine, after it sat overnight.
The very first OBD-II codes thrown were Cyl #'s 1, 2 and 6 before I replaced the plugs and wires. Cyl 1 & 2 had bad boots on the end of the plug wires, cyl 1 & 6 have low compression, but are not dead. I think I had a single Cyl #5 misfire before replacing the wires and plugs, and after replacing the plug wires the only misfire I got, about 20 in row was, is now Cyl #1.
So here is my question(s). Since I have no antifreeze leaks yet, and thus no antifreeze signs of a head gasket leak, the oil and antifreeze are normal, and no gas bubbles in the coolant overflow bottle, etc, and I still have 81 PSI in cyl #1, what if I pull the valve covers and re-torque the head bolts, then run some heavy duty block sealer through the coolant system to reseal any "trace" head gasket leaks, then just in case I have some cylinder/piston ring wear in the low compression cylinders I could add some Restore to the oil to bring the cylinder compression back up some. Any one think this has a chance in hell of working, if so how long might it last? I realize if it's a tiny valve leak non of these would work, but what are the chances of the valve resealing itself within a few hours of run time on the freeway with the new plugs and wires and repeated resetting of the OBD-II code? In other words how bad is 81 PSI? I could run it and retest it after an hour or two run time?
At this pint, I have no way of knowing for sure if the low compression on #1, 81 PSI is due to head warpage, head gasket beggining to leak, cylinder or piston ring wear, or even more insidious something like piston rings lining up temporarily, a temporary or permanent valve sealing problem, or some of several of these!
Since it is an overhead valve engine , should I pull the valve covers next and inspect the rockers and valve springs?
The last note of data is that the cleanest new spark plug was in Cyl #1, still looked brand new, but since the computer keeps turning off the injector and spark for #1, I am not sure that means anything. The highest compression cylinders showed just a trace of carbon just below the threads on the steel area. No carbon on three of the other plugs including #1.
Keep in mind that there were several problems at the same time, battery died, a few days later the radiator hose blew, so it is difficult to blame the #1 low compression on just the blown radiator hose (age) and the overheating it caused. If plug number 1 was not firing due to the bad plug wire boot being rotted ( I discovered the boots on the plugs on #1 and #2 were rotten while trying to solve the engine misfire problem), it could have washed the oil off of the piston rings and worn the cylinder wall in a very short time. But there is no sign of oil on the old or the new Cyl #1 spark plug, or any other spark plugs for that matter.
In fact it is surprising how clean the used spark plugs were after at least 20,000 miles on an engine with possibly 198,000 miles on it. Unfortunately I do not know if this is the original engine, but it does not act like a worn engine as far as oil consumption is concerned.
Or am I hasta. I has 198,000 miles on the odo. My son bought it 20,000 miles ago. It's been a relaible low cost car up to now.
Thanks for the help people!
81 PSI (Cyl 1)
125/120 PSI (Cyl 4)
145/155 PSI (Cyl 2)
150 PSI (Cyl 5)
155 PSI (Cyl 3)
115 PSI (Cyl 6)
+41 psi ( 1 to 4)
+20 psi (4 to 2)
+/-5 psi (2 to 5)
+5 psi (5 to 3)
-40 psi (3 to 6)
-34 psi (6 to 1)
