Loud Tickin on 95 XJ
Get out the long screwdriver or broom handle stethoscope and see if you can track it down a bit. Might be a sticky lifter or maybe the common problem of the flexplate bolts backing out.
Also pay attention to the injectors.My injectors make a lot of noise and had me fooled into thinking I had a valvetrain problem.
That doesn't explain why it only does it when it's warm.
ive checked the flexplate and its fine, the exhaust header is less than a year old and is fine, im leavin for 2 weeks and when i get back its gettin fresh oil again and some marvel mystery oil, and if that dont fix it the motor is comin out
Lucas oil additive may work a little better than Marvel Mystery Oil.
Mine was making horrible clacking noises too (230,000 miles on it) and I dumped in a can of Restore. Noise disappeared in less than 50 miles.
