Lots of XJ Cherokee Parts
xjbump
Updated Again
Originally Posted by xjbump
PLEASE BEFORE YOU POST OR PM CHECK THE THREAD FOR UPDATES AS I CANNOT EDIT THIS LIST BUT I WILL UPDATE AS THINGS ARE SOLD!
Axles/Suspension/Tires/Wheels
1 – 8.25 Rearend – welded 3.55s – from 95’ $50
1 – Ford 9” – Fullsize stock 3.54s – 5 on 5.5 – Not Nodular $150ea
1 - Steering box $25
3 – Rear Driveshafts – All from AW4s - 1 older style and 2 newer style $10ea
2 – Prs of front coils from a 00’ & 01’ $10pr
1 - Pr of tires with stock Cherokee 5 star grey rims, size 30x9.5x15 - 1/4" tread $50
Engine/Tranny/Tcases/Accessories
1 - Computer from a 99' XJ w/ 2.5l & AX5 $50ea
1 – Computer from a 95’ XJ w/ 4.0 & AW4 $50ea
1 – Water Pump $10
3 – Starters $20
2 – Water Necks w/Temp Sensors $10
1 – Coolant Res. Bottle $5
2 – Older style washer bottles $5
2 – Newer style washer bottles $5
1 – A/C Comp. Units $15
5 - Diff. size vac. bottles(round/oval) $2
1 – ABS Booster & Master cylinder 97+ (00’) $25
1 - Poly Gas Tank w/Pump 97+ $30
Exterior/Interior/Elec.
Pre96 Parts:
1 – Reargate black $25
6 – Prs of reargate strut arms $10
3 – Hoods – White & black- paint is good $50, red- paint is bad $25ea
1 – Header Panel w/lights – black $50
1 - Set of Chrome Bezels and Grill, grill has a piece missing off bottom $25
2 - Drivers Marker lights $5
1 – Front bumper – 1 chrome $20
1 – Set of front bumper brackets $5pr
1 – Pr of Fender Supports w /horn $5
4 – Prs of Wiper Arms w/blades $5pr
1 – Auto T-handle Shifter $5
1 - Grey Arm rest with latch $5
3 – Rearview Mirrors $5
1 - Taillights $15pr
1 – Gauge Cluster w/Tach – grey from 94’ has small elec. Plug on back $15 1 – Temp. Selector Switch $10
A ton of Pre96 Dash switches and plugs
97-01 Parts:
2 - Hoods $50 black/white
1 – Pr of Air Bags w/sensor unit D & P 97+ (99’) $75
1 – Headlight Switch 97+ $10
1 – Front Pass. bumper endcaps $10 and 1 - center plastic piece $5 - dk grey 97+
1 - Rear Bumper black & endcaps grey 97+ $25
2 – Center dash trim- Drk Grey 97+ $10
1 – Grills 97+ - Painted Black w/chrome centers $20
1 – Drivers Rear door power window motor & assembly 97+ (00’) $20
1 – Drivers side F & R door handles w/power lock, rods & latch 97+ $20
1 - Steering Column w/Airbag & Key 97+ plus pass. airbag $100
1 - Center Console $20
Dark grey Int. Pieces from a 99' 2dr. $5+
any chance you got any 97+ aux fans laying around?
need headlight switch for 97 and front right turn signal light plug with enough wiring to splice.
thanks
tom
I know its not on the list...
but I am looking for a trailer tow light package for the 97+
any chance you have one of those?
i never thought about doing it that way... but if you happen to come up with a second i'd be interested.
