- Thornton, CO
...but putting someone down because they fail at spelling is really petty.
I'm not sure that I've seen anyone calling him any names, or telling him to suck a shotgun....................:dunno:
You are honestly telling me that I have not changed my typing since I first started?
Never a dull moment /don't feel bad dlue i can;t type worth a shizzle either
I'd of never guessed.........:exclamati
Just came into this, read the first post and then posted mine. But seriously, a forum is not a place to berate each other about the way they type or spell.
If you dont understand what he is saying, then ignore his posts and move on. Giving constructive critizism is fine, but putting someone down because they fail at spelling is really petty.
da interwebz has brot don da englsh language ta shrt tiping. yes it is bad, but if he is trying then so be it. its alot better then 133t 5p34|< \/\/1[|-| r3411y 15 A|\/0Y1|\/g
I am not picky with things like that.
I would have never guessed. I'd of never guessed. I wouldn't have guessed.
All of these would be acceptable by my standards, for the forum. The use of a preposition in place of an auxiliary verb does not bother me. However, something like this, would:
I'd never guessed.
The front is the same, the rear is factory sprung under. A spring over on stock leafs, which are longer than an xj by the way, nets about 5" lift.
XJ-Grin said:The MJ front is coils sprung, identical to an XJ. Rear is leaf, but not the same leaf packs XJs run, rather they are longer. I believe Yella was looking at prototyping a BigOffroad MJ spring. You also can get @5" just by a spring over conversion, since MJs are spring under stock.
uuuhh, as opposed to "gross"??what do you mean nets?
