Fletchs90xj
- Vancouver BC, Canada
So the next and prolly last mod for a while on my project XJ is doing gears and lockers. I don't plan on going any bigger then 32" tires maybe when the 31s wear out. I set on putting ARB lockers in and prolly 4:10s. SO will I run into problems with the ol D35 when it gets lock and geared lower or should it be just fine? And if an axle swap is iminent(sp?) I'd prolly go with an 8.8 w/db. But I don't want to have to change out the rear if it will sufice.
I generally take 'er easy on the trail but do like to challenge myself. I guess the nick name BOF ( Balls out Fletch) might say otherwise
thanks for any thought on this
Fletch
Fletch
