long arms
rocklandxjer said:
wow... a 12 year old william shatner and a guy who catches more flame than a wood-burning stove... whats not to like.
:shakes head in disbelief:
i just actually read the thread.... sigh... man alfred, you need to do a LOT more research before you build... im sorry, i dont want to flame you any more than you've already been, but damn man...
drag link [ok steering as a whole]
"frame" plates
cross member
welds
bushings/joints
these are things that you MUST adress... for your sake man.
sheesh
good thing you spoke up. I dont think he got the point.
Let this thread RIP____________________________________
no more posts:D
Al... buddy.
You really had the XJ GAWD's scared for a bit there. Thankfully you did a bit of soul searching and seeked out profesional help. Pat on the back for you. Them XJ Gawd's are smiling now. Knowing when your in over your head is a sign of confidence. Those fellow XJ'ers that are in your area, I think once they see that a proper build was done by a competent shop. They will welcome you onto the trail with rolled up tow straps, Where before, they would have scorned you on the trail with unrolled tow straps.
PornstaR said:
The things some do to make themselves feel better.
"Bud light presents.........You go Mr. Longarm builder"
:laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
:cheers:
POSJ said:
...so you don't have money to make shit correctly? But you can take it to a shop and have full-widths and a full suspension re-build? :bs:
Tyler-
i do, i just dont take my time like i shuld. i bought some heim joints and some tube for my steering. im going to do something simmular to this http://www.naxja.org/forum/showthread.php?t=918210&highlight=hi+steer
i decided to build the axles before i do the swap, 513 gears and eather a detroit or arb lockers. im going to be going with a hp 44 in the front and a 8.8 in the rear, using coils front and rear
hey, don't do a mock of that steering.
yea you can get the same parts, but buy or make a track bar bracket that runs on top of the tube. (jks, tnt can make them). then you can run tierod OTK and draglink on the bottom of the pitman:rolleyes:
I added the JKS bracket to my currie9. welds to axle, and the springcup/mount in two places. this is using WJ knuckles though. But you if you go all OTK it wil still work out. built the steering an tracbar. this is right after i was done, and again there are soooo many steering threads out therrrrrr
X2
With the JKS over the axle bracket, and 1-ton TREs OTK you can get your drag link and track bar perfectly parallel. You may be able to get pretty close with the heim joints.
I don't have any pictures that show my knuckles, but here is one that shows the links.
I'm also running a full width HP44, using stock ford knuckles.
What are your plans to locate the axles? Are you going to re-use the radius arms up front and 4-link the rear?
