Getcha_Sum
- Great Falls Montana
Custom built
3/4in Heim Joints with misaliagnment washers (2 extra)
1 1/4" solid stock sleaved with 1.5" DOM
Polyurethane bushings at axle end with greaseable bolts
You will need to weld on new mounts at axle end cannot use stock brackets
heim end will bolt right into existing crossmember holes
moves axle forward 1.5"
$75
Stock YJ brake hoses front and rear brand new (used as extended brake lines on xj) $20
Ford f150 coils give 3.5 inches of lift on xj $10
1" coil spacers $5
85 XJ stock springs fron and rear coils $10
$20leaf springs
1.5 lift shackles $10
Partings out d30 and 35
less than 3,000 miles on front brakes and wheel bearings
stock gear ratios no lockers
I can send pics just ask
I'm sure I missed something so just ask
$75
1" coil spacers $5
$20leaf springs
