vintagespeed
- Upland, CA
I got my rotors from Tri County Gear in Pomona CA, machined & ready to bolt on. I think they ran me about $200 for the pair.
Goatman said:....If MM uses their Bronco II hub, I would assume it's not very strong, just like when Warn's kit first came out. Considering this, and since Warn hubs are generally stronger than MM hubs anyway, I would spend a few more bucks and stick with the proven product.
My .02
XJCHUCK72 said:Warn's kit is stronger alloy shafts and you have to change the rotor. Milemarker you don't have to change the rotor, but there is no strength advantage.
brcomputer said:SO I hear lots of Kudos for the Warn kit....
But what about the MM? Does it not come with an alloy outer?
I'd like to have the alloy shafts inner & outer eventually, and run weaker hubs. Much easier to change out a hub .... assuming they go in/out the same way they did on my Bronco....
So we are looking at about $750 for the warn kit plus maybe $175 for rotors. Comes with strong hubs (I'd prefer weak arse ones) and an alloy outer for sure...
Milemarker is about $630 plus the same ~ $175 for rotors. Have potentially weaker hubs and still don't know about the shafts.
I emailed MM about the outers and whether or not they are alloy so hopefully I'll hear from them soon....
brcomputer said:OK, so would warn outers work with the MM kit I wonder? Just curious....
I guess I'll have to fork over the major dough for the Warn setup and just try to get some hubs that will act as fuses...
Vintage, the hubs that come with the warn kit are premium? DO they have a standard one that will fit? Will hubs from MM & Superwinch, etc fit the kit as well, or are they specialized Warn hubs just for that kit? I'd think that if the Bronco II hubs fit it then I could get spares from any company I choose ... right?
Jeep Biscuit said:I don't know where that rumour came from but it is false. Rotors indeed have to be cut on the MM kit.
XJCHUCK72 said:Sorry for posting, SPOBI, I believe I read it here on the boards,![]()
So basically from what I gather from this is that, the MM and Warn share the same parts, but Warn has alloy outer shafts, right? And other than the two unnique parts the rest comes from a Ranger or Bronco II front end.
Anyone have any info on the 5x5.5, I keep hearing this one is supose to be stronger.
I know Goatman has some good info, he knew about the realtion to the Ford parts, but he's probably having funin MOAB already.
haligan said:I have been running the mm kit now for about 3 months and have had no problems with it. It makes a big difference on the highway. i have not had a cheance to do much hard wheeln yet so as far as strength goes i am not sure. i am very happy with the kit and do not regret buying it over the warn kit.
brcomputer said:AH ....
Well, NOW we could probably do the same thing for a lot cheaper eh?
Especially if one can use stock ranger rotors ...
