WheelinJR
- Portland, Oregon
Not real extreme but here it is...This is a one off I did for Jeff (nitrospeed racing).
He wanted a rail that ran the length of the rack, and so I stepped up to build it.
Basically, this is a Warrior rack with 6 gutter mounts instead of the normal 4, and a special outer clamp piece that merges them all together. This was a pain to make, but it looks really sharp
Anyways, the outer pieces were cut to length and I sheared a taper into the ends. Then I tossed them in the CNC Turrett and snuck some 1.25" holes into it. Finished them off in the press break, and had the clamping tabs welded on. Then off to powdercoat!
Here's pics, it was dark!
