E EnderAZ NAXJA Forum User Location Tucson Apr 27, 2013 #1 I bought a Rusty's 4.5" lift kit and the center pins don't seem to want to drop into the axle. Any ideas? Axle is a chrysler 8.25 and the XJ is a 93. The lift kit I'm trying to install is a Rusty's 4.5" spring pack.
S scottmcneal NAXJA Forum User Location not here Apr 27, 2013 #2 Are the pins in the leafs bigger than the holes in the spring plates? If yes, i would drill them to match.
E EnderAZ NAXJA Forum User Location Tucson Apr 27, 2013 #3 Nevermind, I got it....... Glad I didn't have to drill it.
S scottmcneal NAXJA Forum User Location not here Apr 27, 2013 #4 Good to hear, but they are easy to drill a little bigger.Had to do mine and it only took a couple of minutes
xcm NAXJA Forum User Location Southern Oregon Apr 28, 2013 #5 Chuck the bolt up in a lathe, and turn down the head OD, done and done.
C ChiXJeff Curmudgeon NAXJA Member Location SE MN Apr 28, 2013 #6 Or chuck the bolt up in a drill, and turn it down on a stand grinder.
S sunburned NAXJA Forum User Location So. MD Apr 29, 2013 #7 Had to drill out my axle mounts for RE leaf springs.
M Mpeckham22 NAXJA Forum User Location MA/NC Apr 30, 2013 #8 hm... i just pushed really hard as the axle went into place
Z zachandandy NAXJA Forum User NAXJA Member Location Patterson, Ca Apr 30, 2013 #9 Why would you pull the bolt to turn the head down when you could drill the perch in less time than it takes to get the bolt out and back in?
kastein NAXJA Member NAXJA Member Location Rainy side of Washington Apr 30, 2013 #10 Agreed, I'd rather drill the perch, there is a lot more "spare" metal there, reducing the bolt head diameter changes things pretty significantly in a hurry. And it's way easier, slide the axle out a little, grab the drill, and have at it.
