wickedwillys62
- thorndale pa
1991 Jeep Cherokee never wheeled 4.0 5 speed ax15, with 166,000 miles, 6.5" lift, high pinion non dysco Dana 30, 29 spline chrysler 8.25 rear axle only has 68,000 miles on it 3.55 gears. set of custom rock sliders, new skyjacker shock in the rear. Custom modified swing out tire carrier. 31/10.5/15 (have matching tire for spare just have not mounted it yet.) new valve cover gasket. np231 transfer case, with a 1 1/4" T case drop, no drive shaft vibes. the clear coat was peeling. so we sanded and removed all the loose clear coat and primed the jeep. has a new clutch with less than 5,000 miles on, clutch master, save cylinder, pressure plate all new. I have a newer trim panel for the dash.I replace the hard break line that goes to the rear axle. The jeep might need a new steering stabilizer. It is a good running jeep with very little rust. Asking $3,000 orffer / trade?? . Serious offers will be considered. Cash only. Clean pa title in hand.
![2012-03-15_16-57-46_949.jpg](/proxy.php?image=http%3A%2F%2Fi692.photobucket.com%2Falbums%2Fvv283%2Fwickedwillys62%2Frandom%2F2012-03-15_16-57-46_949.jpg&hash=7063d82cf8a95e423795ce63bc125fdf)
![2012-03-15_16-57-56_108.jpg](/proxy.php?image=http%3A%2F%2Fi692.photobucket.com%2Falbums%2Fvv283%2Fwickedwillys62%2Frandom%2F2012-03-15_16-57-56_108.jpg&hash=0a1d59bbf1392d1ba3584c0be6a7c904)
![2012-03-15_16-58-17_347.jpg](/proxy.php?image=http%3A%2F%2Fi692.photobucket.com%2Falbums%2Fvv283%2Fwickedwillys62%2Frandom%2F2012-03-15_16-58-17_347.jpg&hash=07c0c5b3564208da5679fa0a70fd4bfa)
![2012-05-05_19-18-05_474.jpg](/proxy.php?image=http%3A%2F%2Fi692.photobucket.com%2Falbums%2Fvv283%2Fwickedwillys62%2Frandom%2F2012-05-05_19-18-05_474.jpg&hash=839f2602fc0b07e74b651e0813d1fafe)
![2012-03-15_16-57-24_219-1.jpg](/proxy.php?image=http%3A%2F%2Fi692.photobucket.com%2Falbums%2Fvv283%2Fwickedwillys62%2Frandom%2F2012-03-15_16-57-24_219-1.jpg&hash=1872c27c1f66928ccaf8db5ef23ed75c)
