I have a 88 cherokee and it currently has a 2 inch suspension lift. Is it possible to do a body lift on top of that? Does'nt seem like they make body lifts for it. I just want to raise another couple inches.
Only if you cut the unibody apart from its self or have the very rare proto type that was made in 1982 that was built with a frame.Sorry to inform you you don't have a frame to lift the body up on.Find the the bastard pack budget lift thread by rock lizard fabrication
welcome to the club, and if you use the search feature you can gain a lot of info. Also posting in the modified tech forum, not the street performance forum will probably yield you more results with this type of thread.
