IXNAYXJ
- Wherever the next race is.
Sort of...that's my team.
Just finished the cage and sprung under conversion last night. We'll be leaving Seattle first thing Thursday morning and on the track Friday.
-----Matt-----
(oh, and yes, it was my intent to split the beam to make room for the oilpan - I have no concerns about strength there with the resources available to me, and labor isnt factorered).
so what did you do to it?
We all have various levels of track experience, but we all have some.#1 mod:
Find someone that can drive.
I mean really drive.
Anyone in the crew auto-x or do sprints?
Someone that can drive will be worth 10000000000000hp in comparison to teams that don't have a driver.
Normal people that think they can drive can't. This is why a lot of people that turn up at a sprint or auto-x for the first time in their hopped up über car get spanked the first time out and never come out again.
Interestingly, we did very little to the suspension. Cut the coils and went sprung under with a 2" AAL. Dropped it down a little and the AAL stiffened up the whole package quite a bit. Stock sway bars. Handles GREAT.Technical side: Monkey with sway bars and spring rates to get the b!tch to turn in properly. This will be the biggest issue.
The next will be brakes. XJ brakes suck in general. If you can manage to get a good pad compound you may be able to brake deeper.
Adding lightness will make the power be available when you want it. You may even have issues keeping the rear hooked up. Don't move the fuel tank - you'll need the weight there to keep the rear end hooked up under power - may be a handful with a light tank regardless due to being lightened and the polar moment changing more because of the general lightening programme.
Don't swap in a 2wd beam unless you have a 2wd transmission to go with it. Just start with a 2wd machine. Easier.
Big thing is maintaining corner speed. See driver and turn in above. Adjust with deeper braking zones.
Wish I was closer. I'd drive it for you.
$0.02
I've owned a lot of sports cars and run a lot of Solo events and club track days; I can say without flinching that the Cherokee was one of the most balanced, easy to drive cars I've ever turned a tire in anger in.
Some friends of mine and I were talking about this the other day. If it ever comes to our local road track(Hallet) we are going to try and make it.
We discussed how hard it would be to add a 2nd front sway bar, yes two sway bars. I think it would be do able?
We also discussed the 242 t-case but I think it wouldn't work. Since the 242 is another open differential its possible to just spin 1 tire with the 242 in full time mode. It would suck to come out of a corner and light up one front tire under power lol.
Damn it would be a good time though. Compared to alot of the other cars on the list if you get it light enough its got a pretty good HP advantage.
