xray said:
Did you check out the references in those articles? They are medical and clinical studies. All the medical studies on alcohol state the bad effects with the exception of a few, for instance the positive effect of a glass of red wine. The long term use of alcohol does many things to the body liver, kidneys and it has been proven that alcohol kills brain cells. And what about alcohol poisening and birth defects. Im not trying to change your mind on this subject. I am mearly trying to get a point accross as are you. Do you think norml has all that money to cunduct all these studies?
Of course I checked the references, and of course I do not think NORML has that kind of funding - but where else are pot smokers gonna get their information? I have no problem seeing the benefits of the medical use of cannabinoids. As with any drug related substance, it should be controlled and prescribed.
Here's a fun fact: State and Federal Statutes have organized chemical substances into Schedules based upon 3 initial concerns. 1) Does the substance have a hight potential for abuse. 2) Does the substance have a currently accepted medical use for treatment in the U.S. 3) Is the substance safe under medical supervision.
Schedule I drugs are those with no medicinal purpose or benefit, high potential for abuse and not safe under medical supervision.
Schedule II are those with medical uses under supervision and restrictions, but are still subject to abuse or addiction.
Schedule III are those that also have medical benefit, and are less addictive or abused than those found in Schedules I and II
Cocaine is a Schedule II drug - so should it be legalized because it has medical benefit right?
Amphetamines and Methamphetamines are also Schedule II drugs, so legalize those too right?
LSD and Anabolic Steroids are Schedule III drugs, so why not legalize those too?
Here's the fun part: Those "harmeless" natural drugs that couldn't hurt anyone such as Heroin, Psilocybin (mushrooms) and THC Tetrahydrocannabinol (found in Marijuana) are
Schedule 1 substances. So, by all means, let's let those be legalized....... Yikes.
And surely you don't think they taught lab rats to smoke a joint for those studies do ya? I'd imagine that not none of those medical studies concludes it's research with the statement "Go ahead and fire up that doobie, it's perfectly healthy." From what I understand, the tar from smoked Marijuana is many times concentrated over the tar that results from tobacco, and a pot smoker still ends up with the same associated inhaled poisons that tobacco smokers get. The THC for those medical studies certainly was obtained thru processing the canabis and was administered by adding it by injection or to food. Those studies weren't done to help legalize Marijuana, just a part of a medical study to see what the compounds found in Marijuana could be used for medicinal purposes. It's the pot heads that try to use those studies to their benefit.
