I'm finally getting around to starting conversion of my 2000 XJ to interior & exterior LED lights. Going to do the exterior first, since that's a known quantity for me (this'll be the third vehicle I've done an LED swap on), but choosing the reversing lights is proving tricky.
What I'm going for here is improved light throw directly rearward with performance to the side that is at least as good as a stock 3157 filament bulb. Right now, I've got two contenders in this category:
Number one: superbrightleds.com's High-power 3156/3157:
Number two: autolumination.com's Eagle Eye Tower bulbs:
My concerns are the following:
With the superbrightleds.com bulb, it has only one 3W LED set up for a 130-degree beam pattern. It doesn't sound like this is going to give me the rearward throw that I want, and side illumination will be iffy.
Autolumination.com's bulb looks like it may do a slightly better job with side fill-in, but they don't give specs on the rear-facing bulb. Since they describe it as being 'wide-angle', I'm assuming this means 130 degrees as well - so basically the same issues as I may experience with the other one.
Note that I care less about filling the lens with light than getting it out and onto whatever's behind me - tinted windows at night are awesome for backing into stuff.
Any comments or ideas? Experiments on the XJ with even 25-element LED bulbs haven't given the results I want, hence why I'm looking at these ones - which I have zero experience with.
