Mirage mobile
- MO
I have the OMC off-road mounts on mine. I haven't had any issues with them yet. I've put them through hell so far and theyre holding up great. The only thing I didn't like abiut them was they send you 1/4 rivi-nuts to mount into the pillar and some small machine screws to mount with. I ended up drilling the holes in the brackets and mounting with 1/4" rivets.
http://www.omcoffroad.com/apps/webstore/products/show/5449824
Where these mount even IF that happened, it wouldn't be an issue. The equipment I work on every day at work have panels riveted all over them and very rarely have issues with leaks even with 900k miles on them. I think these will be fine.The only thing with those rivets is that they can and will round out over time and lead to water leaks.
Just be careful of the rivets wallowing out over time. That's the reason I didn't go that route.
If they wallow out, you'll start getting water leaks.
is this all you can say about rivets wallowing out? have you tested it for yourself or are you just throwing out false info? i've read 3-4 posts from you in this thread alone talking about wallowing out and leaks.
dont use cheap aluminum rivets and it will be fine, for heavens sake airplanes have rivets all over them. :wave:
The pure ammount of led light bar brackets available for sale is a bad omen for our scene... how embarassing.
