First question - how do you know it's your head gasket that's leaking? Since you didn't mention, I thought it prudent to ask...
Unless it's a coolant leak into the cylinder, there are a few other things to check - depends on symptoms. Please edify us...
Another note - I've had the heads off of my 87 and my 89 (different reasons, but wound up changing lifters both times for good reason,) and it was quite possible to remove the manifolds still bolted to the heads. This allowed me to service the manifold gasket with room to spare, and install the manifolds and head as a unit. This is far easier than wrestling with the manifolds in the engine bay and fighting with the lower rear manifold bolts... I see no reason why this should not work on your 2000 as well as it did on my 87 and my 89 - the basic parts are the same, even if they were improved in the time between.
Also, make sure to label all the wiring. I just pull the head with manifolds, sensors, fuel rail, and all still attached - simply to put it on the workbench. I do what needs doing in the shortblock, then I turn around and service the cylinder head and associated parts as well. The only sensor I remove prior to pulling the head assembly is the oxygen sensor - it's in a bad place for hanging up on things.
Anyhow, why not tell us what's going on so we can make sure it's your head gasket that's leaking and not something potentially far simpler to work on. If you do end up pulling the head, plan on a day for the engine to be DEAD COLD before you start working (24 hours cool-down) and a day to do the job. I can have the head R&I done in a long afternoon, barring problems, so it's not that difficult.
5-90
