Please bear with me, i done alot of reading and searching but i'm a little confused here, so help me out please :worship:.
I recently got hold of a 99 XJ with 147k on it and was thinking of doing some major build ($$$) but would like to make sure the overall condition of the Jeep before throwing in the $$$ thus these tests.
Here are the result of my compression test,
Here is a video of the leakdown test, with cylinder #1 at TDC (compression stroke, i double confirm with the marking on the harmonic balancer and the timing cover marking).
The only leak i detect is coming from the crankcase (no bubbles in radiatior, no hissing sound from exhaust, no hissing sound from intake manifold).
Here are some questions which i really appreciate if i can get some help,
1) With the low compression numbers i have, why is the leak % within the "low" range?
2) In the video, the % of leak went up when turn the crankshalf in an attempt to simulate when cylinder is NOT tdc but as i stop, the leak when down as if the engine was trying to seal up the leak.
I hope you are understanding me.
I tested my leakdown test kit with an air blower attachment to make sure is working and i was getting around 60% stable leak, therefore i conclude that there is nothing wrong with the kit.
Would really appreciate if someone can advise.
Thank you very much. :worship::
Went over to O'reilly and rented another kit.....getting same (close) numbers.
Here is an update on warm engine (99'),
..... Dry ...Wet
#1.. 72...90
#2.. 78...90
#3.. 75...89
#4.. 81...92
#5.. 81...90
#6.. 90...86
Numbers looks better but still not in the 100's but numbers looks fairly even through out.
Thx.
