bwildered NAXJA Forum User Location Allen, TX Dec 15, 2009 #1 Sorry if this is a lame question, but did a search and didn't find an answer. I need to replace the bushings on my RE superflex (non adjustable) LCA's. Will I need to reset the caster of the axle once the new bushings are in?
x2elite NAXJA Forum User Location Texarkana, AR/TX Dec 15, 2009 #2 No you shouldn't as long as you are running fixed arms, and you don't adjust any of the other components.
bwildered NAXJA Forum User Location Allen, TX Dec 15, 2009 #3 Thanks...I didn't think so. I had the alignment done after the lift was installed, so wasn't sure if the LCA's would have any effect.
