Last Rattle in the Hatch
jammerjamesharmon
austin
"One" of the rattles in my hatch turned out to be the wires and running down both sides of the rear window. I could not see an easy way to stuff foam in there to take up the space so the wires would not move around causing the rattle. I drilled a couple of holes on both sides of the window on the inside, about wher the seal for the hatch rest and injected the expanding foam used for home construction. Plugged the holes so it would not come back out until dry. NO MORE RATTLES!!!!!!!!!!!!!!!!!
James
http://www.geocities.com/jammerjamesharmon/
what else did you do to get rid of the rattles. my 92 rattles like crazy. any suggestions? TIA.
