lawsoncl
- North Idaho
orchimaxi said:Thats the sort of combo I'm looking for! The GPSMAP 60c is a bit pricey... we'll see if I can swing it. Any other options as far as a solid handheld that'll work with a laptop? The 60c might be rugged enough to be worth it...
The prices on the 60C should be dropping due to the newer 60Cx and 60CSx. If you think you'll ever need more memory or want more maps in the unit, I hihgly recommend going to the 60Cx as it uses an upgradeable memory card. The newer x series also has better reception and a bit faster processor. I picked up the 60CSx a few months ago for $330 after the $50 rebate. It is a bit small for driving navigation but works well enough and works great for geocaching. Don't forget to budget for buying a decent map set, although you can find some of the older Garmin maps out there on the web (specifically mapsource4 which doesn't require a code and has routing).
