keep destroying driveshaft slip yokes, what drive shaft do you guys run with your 8.8
Motoxic2
Pennsyl
i have an 8.8 in my xj along with a hack and tap sye im running a 70s bronco driveshaft that works well but I keep blowing the ears off of the slip yoke on the driveshaft ive done it 2 weekends in a row, what driveshafts do you guys run with your 8.8 swaps? I need something tough since this is only for offroad and these bronco slip yokes aren't holding up. any help is appreciated also im only running 33s but I do push the truck so this might be part of the problem. thanks in advance guys.
Your pinion angel is wrong. Probably pointed up too high.
