Karma 2012
If no one else closer takes it, I would like the foglight switch panel piece.
mj specific: located in santee, ca
the rear cab inside plastic trim piece that runs side to side right underneath the back window. it's out of an '87, i believe and is that weird orange-y tan color. obviously you could repaint it with plastic trim paint. in good shape, no cracks or broken sections. one or two of the little plastic push pin retainer slots on the back were cracked during an overzealous removal, but i fixed 'em with clear two part epoxy. i'll take a pic of it tonight.
4 Free 235's on stock steelies, one of the rims is missing a hub cap. the rear tires are extremely dryrotted and low on tread but still hold air. The fronts have tons of tread but seem to be out of balance/round and one has a nail(DW at 55).
I have a couple 33s, fairly low tread but in good condition. They'd make for decent spares. One is on a chrome wheel, the other is loose but could be sent with a matching wheel. Used to be Speedbump's but he moved to NY.
Darky you coming this way soon? If so you can drop them here if nobody needs them.I have the rest of that stuff.lol
Hey darky can you hold the 33 with the rim for me, my buddy trevor needs a spair tire/rim thanks dude :D
Sounds good on both counts.
Scott, I will probably come down there soon to do my coil spring pads whether I buy the new axles or not, especially now that I have my truck back on the road.
Ted, whenever we get together to exchange cash for pretending to be a rock star on PS3, I will bring the mounted tire.
I have some recorder stuff for you as well if you are coming out.
