If these will work on a 96 with power locks, I need the rear passenger door latch assembly. Basically everything that goes inside the door.
The parts came out of a 95 so it should fit.
Mike do you mean the latch that goes in the door and latches to the striker plate on the B pillar?
I should have it.
I really need stock mirrors (left/right) if anyone has a set?
Door internals for early model 4 door, power Windows and door locks etc.
i have a pre 97 drivers non power mirror with cracked glass if that will help you out Rob.
painfully obvious.I have never even looked in a mirror.
between the two of you I guess I would have a set, but how hard is it to change the glass out? I have never even looked in a mirror.
