Junkyard upgrades
i did this yesterday. snagged a rear view mirror with lights from a monte carlo (alot of mustangs have them too).
$7
one wire from the fuse panel and you have map lights.
Really neat, but some early-90s XJs (seen them anywhere from a 91 to a 96 now) have a neat dome light with two lensed map lights on them. 100% OEM, plug and play. I loved mine but I replaced it with an overhead console.
There's one in the yard at Sam's in Worcester right now actually...
My 97 has the mid 90's style dome lights, and I had to trim the head liner to go to the map light dome. Other than that, it's an awesome upgrade.
my 89 has squat. i think it is below the base model even. the dome light switch is not working on the master switch so i have no interior lights unless i open my door.
Im fairly new here, but love the site, so I thought I throw in my 2 cents.
2005 and newer Chrysler 300 and Dodge Chargers have a 17" by 7.5" steel wheel with a bullethole pattern as their base wheel under hubcaps. The bolt pattern is 5x4.5 and the hub is the same as our Jeeps. I test fitted one to my MJ and it fit perfect. The backspacing measured between 5 and 5.25 inches... wasnt sure where to measure to at the bead.
Also, the Dodge Charger and Magnum Police versions had 18x7.5 steel wheels in a nice 5 spoke pattern with all the same measurements as above. I would love to have a set of these for my next project.
xj ranger i have heard of a yj and a durango swap for the steering box.
I know nothing about the Durango except that it is reputed to be stronger & similar ratio
The YJ box uses 4 mounting holes so you will need to do some drilling & perhaps use YJ frame spacer. it is also a steady ratio, not as nice on the street but stronger off road. Again, this is by reputation - my steering is bone stock.
i made the same kind of a thread over on jeepforum.....here is the list we compiled
Suspension & Lift:
1. ZJ V8 Upcountry Coils = 1-1.5" lift
2. F-150/Bronco Coils ('70s-ish) = 4-4.5" lift
3. S10 (P/U or Blazer) leaf packs (cut eyes off S10 main and bolt pack under XJ main) = 3-4" lift (may require use of degree shims)
4. Dakota Bastard Pack (do same as with S10 pack) = ~4" lift
5. JK shocks = slight mod to fit 2-4" lift (some dispute)
6. MJ Shackles = 1/2" lift
7. Camaro Spring Isolators = 1.5" lift
8. Full size Blazer Bastard Pack (do same as S10 pack) = 4-4.5" lift (may require use of shims) may be stiffer than S10 leafs
9. ZJ spring isolators = stronger, metal core, can be stacked
10. GM fullsize pickup shackles ('95-99) = 1.5" lift, better shackle angle
11. Thunderbird Front Coils ('83-97) = 3-4" lift (varies in lift and softness by year and trim package), will need top plate from strut too
12. Any 2.5" wide leaf spring can be used between to make a bastard pack (they may differ in stiffness and lift)
13. S10 Shocks (Rear only) = good for the lift you will get when you do a bastard pack
14. TJ Lift Coils (front only) = provide 1" less lift on an XJ than on a TJ
Brakes:
1. WJ brake booster
2. WJ Master Cylinder
3. YJ Brake Lines = 3-4" longer
4. Dodge Ram Van Brake Lines = 10-12" longer (for big lifts)
5. WJ Rotors/Calipers = bigger brakes and more stopping power (will fit 15" rims)
6. ZJ brake booster, master cylinder, proportioning valve = may need for disc conversion
7. XJ '95+ brake booster and master cylinder = dual diaphragm
8. Dakota Rear Softlines ('95-00) = 6" longer
9. GM C/K1500 Front Softlines ('90-95) = 6" longer
10. KJ disc brake set-ups can be used for a conversion on your XJ axle
Axles:
1. Ford 8.8 inch ('97+) = need spring & shock mounts (3.55, 3.73, or 4.10, maybe LSD, Disc Brakes)
2. XJ I-4 & some V6 = may have 3.73, 4.10, or 4.56 gears may have vacuum discos
3. XJ C8.25 ('97+) = bolt in and upgrades to 29 spline (strength comparable to D44)
4. XJ D44 = found in some but not all '87-'89 XJ's with Towing Package
5. Lincoln Lockers = welded spider gears, operates like a spool, must be a GOOD welder
6. MJ D44 = need new spring perches and shock mounts
7. XJ D30 = ('95-'99) non-disconnect, larger u-joints, high pinion, bolt in
8. Homebrew posi-locks for '84-90 vacuum disconnect D30s, eliminates vacuum actuation (use search function)
Front End & Steering:
1. ZJ V8 Tierods = beefier & bolt in
2. WJ Knuckles/Tierods/Draglinks = beefier and crossover steering
3. Durango Steering Box = beefier
4. 350 or 351 Power Steering Pump = helps with oversize tires (requires welding)
5. WJ LCA's = more tire clearance (some grinding required)
6. ZJ pitman arm = 1 inch drop over stock
7. WJ rear LCA's = replace XJ front LCA's, 2" longer to accommodate a lift, some grinding required
8. WJ power steering pump (fits '96+, plug return hole, and use XJ pulley)
9. V8 ZJ front sway-bar
10. JK rear UCA = use as XJ LCA, its about 1-2" longer
Engine/Transmission/T-case:
1. Newer XJ intakes (may require some modification)
2. Mustang 5.0 Injectors = near bolt in (have 4 holes instead of 1, more fuel, better spray)
3. ZJ V8 alternator = more power to run accessories (some grinding required) 136A
4. Ford Electric Fan ('90-95 3.8L Taurus, '87-93 5.0L Mustang) = replaces mechanical fan, more cooling (8C607)
5. 2.5L Dakota Alternator = bolt in, upgrades to 117A
6. Dodge Neon Injectors = better throttle response
7. '94+ V6 Dakota AX-15 = bolt in (but must use XJ bellhousing)
8. ZJ and WJ stock tranny coolers with stacked plates (even an upgrade for us with the stock fin style)
9. 5spd crossmembers give 3/4 inch t-case drop on autos with no loss in ground clearance
10. Hoodvents (i.e. Lebaron, Laser, Turbo Thunderbird etc.) = help keep ur 4.0 cool at low speeds
11. You can convert the closed system to open without replacing your radiator by using the fill cap from a 4.7 durango or dakota, cutting it into your upper hose, and replace your bottle with an MJ overflow tank or any that fit. Then cap off or eliminate the T'ed lines in the heater core.
12. Homebrew Slip Yoke Eliminator (use search function)
Body/Interior/Armor:
1. 97+ mirrors are direct bolt in to older XJ's and allow you to fold them in on tight trails.
2. MJ/2 Door XJ Bucket seats = tilt forward, bolt in
3. ZJ gas tank skid = can be modified to fit 97+
4. GM power antennas replace your broken XJ's with little modification
5. XJ '97+ doors onto older cherokees = one piece windows and better mirrors
6. XJ overhead console = most commonly found in '00-01 or higher trim level, provides space for switches etc.
7. '97+ center console = can be made to fit '96 and older, gives you cupholders!
8.'96-00 Ford Explorer hatch shocks = lift your hatch about 3" lower but are beef (ever see one that doesn't work?) need modification for '97+
9. OEM skid plates (Front, Tranny, T-case, gas tank, found on "up-country" package XJ's)
10. OEM swing-out tire carriers, get the bumper with it, found mainly on '84-'90 XJ's
*feel free to ask questions about any of these mods
**Also Blazin Den has made a list of links to build threads for us! Recap with Links!
***Here is the Link to the thread on Jeepforum.com where most of this info came from Budget Builds: What Junkyard parts will fit an XJ?
the caravan overhead console is similar to the 97+ consoles , good place for extra switches ect .. zj wj rearview mirrors have the auto dim , a simple 3 wire hookup , power gnd and reverse ..
Dodge Magnum steel wheels: 17x7, 4.5"bs, 5x115, 71.5mm.
(with 255/75bfg mud terrains, takeoff tires from a JK rubicon)
all the cool kids are running them. which would only be me so far...
How's this for a junk yard find?
I need to find some barley longer uca I have right about 5" lift and have alil DEATH wobble and I belive my uppers are like 1/4 to short is there any JY fix :greensmok
There isn't really any known uca swap candidates. That I know of...
And to add to the Junk Yard Upgrades. I found that a set of Tow Hooks off of late 90s GMC Sonoma/S10 4x4s, will bolt to the Sway Bar mounts. You have to drill out one of the Tow Hook holes so it will line up and the threads match too.
swaybar mounts?!? :doh:
someone please remind me to RUN if these need to be used.
:rolleyes:
seriously, dude, don't do it...
yeah...
that's gonna tear out and become a missile in short order.
yeah...
You know so? i have been running it since last summer and have been tugged through Fordyce and haven't had any signs of fatigue in that area.. If its a bad idea, i will take them off. :dunce:
I would not use anything for a tow point that isn't double-shear.
