Captain Ron
- On the horizion
Just the angle grinders.
They sweep from time to time also.
--ron
--ron
And since you give your opinion, I must give mine.David Taylor said:I know you didn't ask for it, but in my opinon, I would never put an exo on a rig that goes to JV. Or anyplace else for that matter.
ROBERTK said:And since you give your opinion, I must give mine.
Thats the dumbest thing I ever heard! Unless you didnt like Any of the sheet metal to resemble a XJ after a few dozen good hard runs...
Jump This said:Sheeesh...Dave had a bad episode with an exo cage once, and he has never been the same since.
Lets not get into the exo cage debate here...:firedevil:
But....a buggy has some serious advantages in big rocks.
And an exo cage is just a realy FAT (wide?) buggy...that doesn't
have any advantages in big rocks.
Ask Bent about rock damage...or
Dan....or Ryan....heck, you could even ask me!
Rick R
David Taylor said:I will try and keep an open mind. Maybe you could help change my mind with your Idea's on the exo. How do you plan on protecting the doors without making the b-pillar
a rock anchor. Maybe you have a two door ? They just always seem to add weight with little or no real added protection
Jump This said:Ya think he meant it in a metaphorical sence??
And I believe I have the record for the longest uninterupted run up Clawhammer, and therefore, I 'own' that one!!:laugh3:
Rick R
David Taylor said:I'm no "Tin Bender" and I know you didn't ask for it, but in my opinon, I would never put an exo on a rig that goes to JV. Or anyplace else for that matter.
CRASH said:Ron actually pays you guys to fawk around with angle grinders and go sailing?
Rick R
ROBERTK said:Cant really protect the "doors" them self and keep it 4dr freindly. But you Can run a roof tube at the apex of the roof lines either side tied to the gutter rails in at least 5 places each side as well as full front lower fender line and tied from a radiator hoop to the lower side rockers. Then a upper fender tube to a cowl area hoop that the roof tubes tie to, back to a rear bumper hoop. Then one more from the rear bumper over the rear tire following the fender line to the rockers. Thats about the best I think can be done. All in all what 150-175lbs in tube.
With something as basic as this you would not only preserve the body some, but allow the full structure some true ridgitness. But you are fully correct in that the doors would not be protected much. But with a nice designed rocker and roof (lower on the side of the roof/side) at least you would preverse the opening areas mostly. And more then anything build a slide area up high and down low as well as full hood area protection and rear body line.
Thats just my .02
Rawbrown said:if you really thing that an exo is gonna do all that in JV, then your in for a suprise. JV is the kinda place that even if you double up on the condom, your still gonna get her pregnant. the hammers are that kind of a whore. the only reason you need roof protection is because your adding the weight thats gonna pull your roof closer to the rocks.
The minute I stopped carrying a spare and a tool for every possible problem, I stopped having those problems. I started wheeling a lightened jeep and I found forward progress to be easier. Rather than grinding a diff into a rock I can grind a diff over a rock and keep going. So you talk about 150-175# like its nothing. Its alot. give it a try, run a trail with 3 people in your jeep then run the same trail by yourself. night and day
XJ_ranger said:Nice to meet you Ben!
There were no Tin Benders there* - thank god the owners of the trail didnt show up... they'da been pissed that we were blocking up the trails for so long!
*Chris Butler may or may not be a Tin Bender, but on the CB he proclaimed "There are no tin benders here"![]()
ROBERTK said:So bens shit (you know I mean that in a good way lol) made it through? What trail(s) did you run?
I am most definitely not a Tin Bender. I saw you guys taking a lot of pics, are you going to post them up? M wife got very few.XJ_ranger said:*Chris Butler may or may not be a Tin Bender, but on the CB he proclaimed "There are no tin benders here"![]()
