- Lafayette, CA
I was welding up some mounts for my trackbar that uses both heims and Johnny Joints, and was trying to use the joints as spacers to try and prevent the mount from getting to small and preventing me from getting the joint back into its place once the mount was fully welded.
The problem was that the joints are often pretty big, and expensive. I was not liking how some welding splatter was getting onto the joints, and I often couldnt get the tip of the welder where I needed it with the joints in place.
Soooo, would anyone be willing to make some spacers that one could bolt in place of a joint? Maybe make several different sizes, one for Johnny Joints, others for small and big RE joints, certain size heims, etc.
Make them 1/16'' bigger then the joint to help with getting the joints in and out.
I thought about taking the joints apart and using the ball, but I didnt want to get splatter on that either.
