Dan Fredrickson
- Sacramento, CA
These axle coil buckets are a direct replacement for the stock coil buckets on a Jeep TJ. Where they're different is in the strength. Our brackets are entirely .25" thick, both the plate and the tube.
The surface of the pad is 6 5/8" diameter and the OD of the locator is 2 1/2" so these are perfect for the TJ but can be used with many different springs also.
They are sold in pairs and should be welded on by a competent person with the correct equipment.
Jeep Wrangler Coil Bucket (Pair) - RuffStuff Specialties
