- MilkyWay Galaxy
This is a bizarre problem. Normally things don't work when the battery voltage is low. Where did you read the 11v? Gauge Cluster or at the battery?
How did you drain the voltage down to 11v? What made you try this?
Are you trolling?
I have actually used that method to see if the battery is totally dead when I first get a no crank situation, and I have used to clean the plates on sulphated battery that sat too long, but always recharged it before trying to crank it. His post wording says or implies the 11 volts is a dash gauge and if it is 84-90 the dash gauges suck.
