Jeep ecco rims
XJBill
Erie, PA
Is there a difference in backspacing between Wrangler and XJ ecco rims? I believe the Wrangler ones have less backspacing but I'm not sure. I would like to get 33 x 11.50's on my stock rims but I think I will need less backspacing. If the Wrangler ones have less, I'll get a set of those and it will still have a stock rim look. Also, are stock rims wide enough?
i just went thru this about a set of canyon wheels.. TJ wheels are 15x8... XJ's are 15x7.. at least on the canyons they are... the backspacing on the TJ wheels are 1/2" deeper.. i'm mounting 30's on it so i don't expect clearance issues in my case at least..
mike
However, the TJ Canyons come with the 30" tire package, whereas on the TJ I believe the Ecco rims were used with "stock" size tires.
Not sure, but I think they are the same 15x7 as used on the XJ.
